Maximum Turtles
- Feb 18, 2014
- Santa Rosa, CA
1992 240 with B230F and AW70, no cruise control.
My throttle spool has had quite a bit of play in it since I got the car, so I took everything apart to clean/ lubricate/shim the pulley. On the inside of the pulley there are some springs, keyed to the bracket and the pulley, seen here, parts 5 through 8.
When I went to reinstall these springs, the inside spring keeps popping loose, making the throttle reset to the wrong position entirely. When I don't install these springs at all, however, the throttle appears to function perfectly (but with slightly less effort), as the throttle body has its own spring to reset its position.
My questions:
1. What purpose do these springs serve (are they important)?
2. Does anyone have any experience with these and how to get them together? I cant get the inner spring to stay in place while I'm installing.
My questions:
