$EEKING 945 TURBO WAGON
- Jan 16, 2012
- 47933 Shipping ZIP; Midwest
What did I miss? Easiest, simplest, cheapest, quickest to check,& MAYBE even fix...
Why would not THE very first thing to check, the quickest, easiest, simplest and cheapest- if the screen is clogged, as mentioned clearly long ago- the condition of the converter, clutches, valve body or pressure tests are moot; are they not?
I liked the concept mentioned in one of the first posts; crud in the pan stays on the pan- UNTIL it gets circulated enough to CLOG THE SCREEN. As an astute observer observed; "letting it cool down" MIGHT just be the sediment falling back to the bottom- opening the previously RESTRICTED SCREEN. Did I miss a salient point in there somewhere?
I learned this concept also holds true for nasty fuel tanks and pump intake screens. I got stranded in a customer's work truck, after being told to not test drive it. I know better now. Maybe.
