Transmissions compared and speeds calculated!
Janne K
Tbricks MIG Welding Champion
Suomen ?bo
EDIT: Ok. So i decided to change the layout a bit. This way it's easier to compare the transmissions.
The driven wheel diameter used in these tables in 62cm, 24,04 inches. gear change rpm is 6800 rpm.
The first set of tables will tell you the difference between the gears, the rpm drops and the rpm drop percentage.
The second set of tables will tell you that at what speed does one shift when shifting at 6800 rpm, and it also tells you the theoretical top speed and the rpm count when driving at 60mph in top gear.
The ratios for the boxes have been found from internet, exept for M46 and Getrag 265. Those came from a Volvo orig. green overhauling manual and a BMW Bentley manual.
Ratios compared:
T5 close ratio (later referred to as T5 CR): 2,95:1 ? 1,94:1 ? 1,34:1 ? 1,00:1 ? 0,63:1<o:p></o:p>
<table class="MsoNormalTable" style="width: 391.1pt; border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0" width="521"> <tbody><tr style=""> <td style="border: 1pt solid windowtext; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> <o:p> </o:p>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> Rpms<o:p></o:p>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> Rpm Drop<o:p></o:p>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> Rpm Drop %<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 1<sup>st</sup> to 2<sup>nd</sup><o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4472<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2328<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 34<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 2<sup>nd</sup> to 3<sup>rd</sup><o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4697<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2103<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 31<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 3<sup>rd</sup> to 4<sup>th</sup><o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5075<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1725<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 25<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 4<sup>th</sup> to 5<sup>th</sup><o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4284<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2516<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 37<o:p></o:p>
</td> </tr> </tbody></table>
T5 V8 Mustang: 3,35:1 ? 1,93:1 ? 1,33:1 ? 1,00:1 ? 0,68:1<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3917<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2882<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 42<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4686<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2114<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5113<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1687<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4624<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2176<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 32<o:p></o:p>
Getrag 265, BMW E28 528i, 535i: 3,82:1 ? 2,20:1 ? 1,40:1 ? 1,00:1 ? 0,81:1<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3916<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2884<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4327<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2473<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 36<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4857<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1943<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 29<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5508<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1292<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 19<o:p></o:p>
Volvo M46: 4,03:1 ? 2,16:1 ? 1,37:1 ? 1,00:1 ? 0,79:1<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3959<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2841<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4313<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2487<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4964<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1836<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 27<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5372<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1428<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 21<o:p></o:p>
Volvo M90: 3,54:1 ? 2,05:1 ? 1,38:1 ? 1,00:1 ? 0,81:1<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3938<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2862<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4578<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2222<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 33<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4928<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1872<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 28<o:p></o:p>
Supra W55: 3,57:1 ? 2,06:1 ? 1,38:1 ? 1,00:1 ? 0,85:1<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3924<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2876<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4555<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2246<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4927<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1873<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5780<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1020<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 15<o:p></o:p>
Supra W59: 3,95:1 ? 2,14:1 ? 1,27:1 ? 1,00:1 ? 0,85:1<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3684<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 3116<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 46<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4036<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2764<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 41<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5354<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1446<o:p></o:p>
Supra W58: 3,28:1 ? 1,89:1 ? 1,27:1 ? 1,00:1 ? 0,78:1<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3918<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4569<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2231<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5304<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1496<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 22<o:p></o:p>
</td> </tr> </tbody></table> <o:p> </o:p>
Supra R154: 3,250:1 ? 1,955:1 ? 1,310:1 ? 1,000:1 ? 0,753:1<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4090<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2710<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 40<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4557<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2243<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5191<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1609<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 24<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5120<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1680<o:p></o:p>
Volvo AW71: 2,45:1 ? 1,45:1 ? 1,00:1 ? 0,69:1<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4024<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2775<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4690<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2110<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4692<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2108<o:p></o:p>
</td> </tr> </tbody></table> Gear change speeds compared (+top speeds and rpm count at 60mph in top gear)
FINAL DRIVE RATIO: 4,10:1 <o:p></o:p>
<table class="MsoNormalTable" style="border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0"> <tbody><tr style=""> <td style="border: 1pt solid windowtext; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> <o:p> </o:p>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 1<sup>st</sup> to 2<sup>nd</sup><o:p></o:p>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 2<sup>nd</sup> to 3<sup>rd</sup><o:p></o:p>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 3<sup>rd</sup> to 4<sup>th</sup><o:p></o:p>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 4<sup>th</sup> to 5<sup>th</sup><o:p></o:p>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 5<sup>th (or top)</sup><o:p></o:p>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> At 60mph<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> T5 CR<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 41mph 66km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 62mph, 100km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 90mph, 145km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 120mph, 194km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 191mph, 307km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2134 rpm<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> T5 V8<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 36mph, 58km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 91mph, 146km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 177mph, 285km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2303 rpm<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> Getrag 265<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 32mph, 51km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 55mph, 88km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 86mph, 138km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 120mph, 193km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 148mph, 239km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2743 rpm<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> M-46<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 32mph, 52km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 56mph, 90km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 88mph, 141km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 152mph, 245km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2676 rpm<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> M-90<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 34mph, 55km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 59mph, 95km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 87mph, 140km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 149mph, 239km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2744 rpm<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> W55<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 34mph, 54km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 58mph, 94km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 142mph, 228km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2879 rpm<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> W59<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 30mph, 49km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 56mph, 91km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 95mph, 153km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 142mph, 228km/<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> W58<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 37mph, 59km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 64mph, 103km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 154mph, 248km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2642 rpm<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> R159<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 37mph, 60km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 62mph, 99km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 92mph, 148km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 160mph, 257km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2551 rpm<o:p></o:p>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> AW-71<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 49mph, 79km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 83mph, 134km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 120mph, 193km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> -<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 175mph, 280km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2337 rpm<o:p></o:p>
FINAL DRIVE RATIO: 3,91:1<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 43mph, 69km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 65mph, 105km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 94mph, 152km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 126mph, 203km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 200mph, 322km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2035 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 38mph, 61km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 186mph, 299km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2197 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 33mph, 53km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 57mph, 92km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 156mph, 251km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2617 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2552 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 36mph, 57km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 92mph, 147km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 35mph, 57km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 61mph, 99km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2746 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 99mph, 160km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 39mph, 62km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 67mph, 108km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 162mph, 261km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2520 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 39mph, 63km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 65mph, 104km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 96mph, 155km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 168mph, 270km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2433 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 52mph, 83km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 87mph, 140km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 126mph, 203km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 183mph, 295km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2229 rpm<o:p></o:p>
FINAL DRIVE RATIO: 3,73:1 <o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 45mph, 72km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 68mph, 110km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 99mph, 159km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 132mph, 213km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 210mph, 338km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1942 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 40mph, 64km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 69mph, 110km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 100mph, 160km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 195mph, 313km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2096 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 35mph, 56km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 60mph, 97km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 95mph, 152km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 163mph, 263km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2496 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 97mph, 156km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2435 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 96mph, 154km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2620 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 104mph, 168km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 40mph, 65km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 70mph, 113km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 170mph, 273km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2404 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 41mph, 66km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 68mph, 109km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 101mph, 162km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 176mph, 283km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2321 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 54mph, 87km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 91mph, 147km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 132mph, 213km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 191mph, 309km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2126 rpm<o:p></o:p>
FINAL DRIVE RATIO: 3,54:1 <o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 47mph, 76km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> <st1:metricconverter productid="72 mph" w:st="on">72 mph</st1:metricconverter>, 116km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 139mph, 224km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 221mph, 356km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1842 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 42mph, 67km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 72mph, 116km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 105mph, 169km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 205mph, 330km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1988 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 63mph, 102km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 172mph, 277km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2369 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 102mph, 164km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 177mph, 284km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2311 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 101mph, 163km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 164mph, 264km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2486 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 110mph, 177km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 43mph, 68km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 74mph, 119km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 179mph, 288km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2281 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 71mph, 115km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 106mph, 171km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 185mph, 298km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2202 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 96mph, 155km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 139mph, 224km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 202mph, 325km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2018 rpm<o:p></o:p>
FINAL DRIVE RATIO: 3,31:1 <o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 51mph, 81km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 77mph, 124km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 111mph, 179km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 149mph, 240km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 237mph, 381km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1723 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 112mph, 181km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 219mph, 353km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1859 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 107mph, 171km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 184mph, 296km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2215 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 69mph, 111km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 109mph, 175km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 189mph, 304km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2161 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 42mph, 68km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 72mph, 117km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 108mph, 173km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 108mph, 174km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 176mph, 282km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2325 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 70mph, 112km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 117mph, 189km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 149km/h, 240km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 45mph, 73km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 79mph, 127km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 191mph, 308km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2133 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 46mph, 74km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 76mph, 123km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 114mph, 183km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 198mph, 318km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2059 rpm<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 61mph, 98km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 103mph, 166km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 149mph, 240km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 216mph, 347km/h<o:p></o:p>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1887 rpm<o:p></o:p>
500dollar744ti
still rides with MrDoug
Falls Church, VA
awesome write up, this will be very helpful to a lot of people, including me! tells me that if i ever make enough power my car will top out at 168mph haha
and will be helpful in deciding my next tranny swap combo
John V outside agitator
Sleezattle, WA, USA
Thanks Poiki!
now maybe the Moderatores could make this a sticky cause it comes up constanly and should come up even more frequently cause nothing will change the characteristics of the car more than gearbox and final drive.
Again Thanks!
That 4.1 with a 2.95 looks to be the best allround set up if you look at all the numbers.
Now on Kevvis car thats what we have except we have 65cm talltires on and so down the road the plan is to swap in 4.3 to make up for the 65s.
silversnail
Any chance you can put in the numbers for the AW71 so those here running autos have and idea on where things are ??
BDKR
Section 9
Horizons Cave
why? i like having a transmission that dosn't **** itself when i make 200+ whp (m46/7, i'm lookin at you)
weak ass transmissions
I'm getting an AW-372. Waiting on shipping. :roll:
Supposedly the same case as the 71/72 but with a torque rating of 375 ft lbs. Does that sound interesting enough for ya?
Yea Right
Malcontent
Nice writeup! I am using a 265 with a 3.54:1 rear gear. The 3.54 may seem tall for a road race gear, but because I do not lack torque and I am bound to a getrag for now it actually works real well. I use 3rd and fourth gear exclusively once underway and fourth is good to 7k at the back stretch at PIR and i suspect a bit more than 7k at pacific raceways. I do miss the close ratios of the M51, but it does no good if it cannot handle the torque.
BDKR
Section 9
Horizons Cave
What is that out of and is it hydro mechanical or does it have a computer?
Thanks
Renny
PS> I'd like to see AWxx ratios in there too.
lockup tcc?
I thought you guys knew about these honestly. Aaron mentioned them in the 'Polishing a Turd' thread. They come from Monteros, Dodge D50's, and some years of 4-Runners. They are Hydro-mechanical.
I don't know about if it's a lockup tc yet.
Janne K
Tbricks MIG Welding Champion
Suomen ?bo
For all those asking about automatic transmission ratios: I do not ave any of the ratios for any of the automatic transmissions.
If you post the ratios i'll do the charts. At what rpm does these things shift at full throttle?
silversnail
Automatic transmission AW71 (740 Turbo)
Reduction ratios:
1st gear 2.45:1
2nd gear 1.45:1
3rd gear 1:1
4th gear 0.69:1
Reverse 2.21:1
redline RPM can varry depending on the setup of the kickdown cable and valve body
Sleezattle, WA, USA
Nej nej Nej Poiki, if you do that you'll be supporting those peoples bad decisions to drive auto-tragique!
In the Therapy world its called "enabling" and it's like if you gave a drunk free booze or maybe gave street directions to a crack addict.
They're all sick with a disease called "can'tbetroubledtodrivemycaritis" and nobody how it's cause or how it spreads,if it's hereditary or endemic or why some people are deluded into thinking driving an automatic is acceptable behaviour for a physically fit person when that flies in the face of societal norms.
So even tho nobody knows WHY some people drive automatics,the only thing we can do,because really we can't just shoot them like a rabid dog, is to never encourage, never advise, no support their bad behaviour.
At the same time there's no point in scolding them, they don't care what the world thinks and in that way they're like other addicts, so don't scold them but DON'T ENABLE THEM.
Janne K
Suomen ?bo
DON'T ENABLE THEM.
:lol:
Oh, come on John. I've given up trying to convert misbelievers a long time ago. It's like you saying that:
"this here T5 is a bitchin' good transmission"
and then me going:
"nah, i doubt that, i'd rather spend hours calculating things and then realize that you might actually have something there rather than just believe you."
Sleezattle, WA, USA
:lol:
and then me going:
But come on, I wouldn't go on and on and on and on if it really wasn't fit to be called "SOOOPER BITCHIN.
I mean I'm not just a kid that thinks that if his car actually starts and moves (somehow!) that that is a major victory in the war of man over nature, an accomplishment----something to Blog about!
I know what you mean though, do I ever cause there are MANY things which are OLD news to me (being old guy who has been doing lunatic performance junk for what? Forever?? and it seems that MOST guys have MORE NEEED to have every last nuance,every detail painstakingly presented before they can dare decide, seems the Intra-web has buried people with SO MUCH OPINIONS that people loose track of what is critical.
That's why I say to look at other brands, other specific uses,and then for people to THINK.
Sorta like the guy on the spring thread was just repeats what some geezers said ---oil on a spring will suck the "temperment" out of them,----he repeats it,i gets a "thanks for great info" immediately, then I say "THINK!---How do valve springs survive 299,999,998 cycles drenched in HOT oil without having the "temperment" "sucked out"?
The problem is in TEXT its hard to say "put aside everything previous,and consider ONLY these facts,then extrapolate over to your problems,what do YOU think?"
