Janne K
Tbricks MIG Welding Champion
- Mar 17, 2005
- Suomen ?bo
EDIT: Ok. So i decided to change the layout a bit. This way it's easier to compare the transmissions.
The driven wheel diameter used in these tables in 62cm, 24,04 inches. gear change rpm is 6800 rpm.
The first set of tables will tell you the difference between the gears, the rpm drops and the rpm drop percentage.
The second set of tables will tell you that at what speed does one shift when shifting at 6800 rpm, and it also tells you the theoretical top speed and the rpm count when driving at 60mph in top gear.
The ratios for the boxes have been found from internet, exept for M46 and Getrag 265. Those came from a Volvo orig. green overhauling manual and a BMW Bentley manual.
Ratios compared:
T5 close ratio (later referred to as T5 CR): 2,95:1 ? 1,94:1 ? 1,34:1 ? 1,00:1 ? 0,63:1<o></o>
<table class="MsoNormalTable" style="width: 391.1pt; border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0" width="521"> <tbody><tr style=""> <td style="border: 1pt solid windowtext; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> <o> </o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> Rpms<o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> Rpm Drop<o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> Rpm Drop %<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 1<sup>st</sup> to 2<sup>nd</sup><o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4472<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2328<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 34<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 2<sup>nd</sup> to 3<sup>rd</sup><o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4697<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2103<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 31<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 3<sup>rd</sup> to 4<sup>th</sup><o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5075<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1725<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 25<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 4<sup>th</sup> to 5<sup>th</sup><o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4284<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2516<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 37<o></o>
</td> </tr> </tbody></table>
T5 V8 Mustang: 3,35:1 ? 1,93:1 ? 1,33:1 ? 1,00:1 ? 0,68:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3917<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2882<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 42<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4686<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2114<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5113<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1687<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4624<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2176<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 32<o></o>
Getrag 265, BMW E28 528i, 535i: 3,82:1 ? 2,20:1 ? 1,40:1 ? 1,00:1 ? 0,81:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3916<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2884<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4327<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2473<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 36<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4857<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1943<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 29<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5508<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1292<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 19<o></o>
Volvo M46: 4,03:1 ? 2,16:1 ? 1,37:1 ? 1,00:1 ? 0,79:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3959<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2841<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4313<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2487<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4964<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1836<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 27<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5372<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1428<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 21<o></o>
Volvo M90: 3,54:1 ? 2,05:1 ? 1,38:1 ? 1,00:1 ? 0,81:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3938<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2862<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4578<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2222<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 33<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4928<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1872<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 28<o></o>
Supra W55: 3,57:1 ? 2,06:1 ? 1,38:1 ? 1,00:1 ? 0,85:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3924<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2876<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4555<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2246<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4927<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1873<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5780<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1020<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 15<o></o>
Supra W59: 3,95:1 ? 2,14:1 ? 1,27:1 ? 1,00:1 ? 0,85:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3684<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 3116<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 46<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4036<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2764<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 41<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5354<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1446<o></o>
Supra W58: 3,28:1 ? 1,89:1 ? 1,27:1 ? 1,00:1 ? 0,78:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3918<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4569<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2231<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5304<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1496<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 22<o></o>
</td> </tr> </tbody></table> <o> </o>
Supra R154: 3,250:1 ? 1,955:1 ? 1,310:1 ? 1,000:1 ? 0,753:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4090<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2710<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 40<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4557<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2243<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5191<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1609<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 24<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5120<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1680<o></o>
Volvo AW71: 2,45:1 ? 1,45:1 ? 1,00:1 ? 0,69:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4024<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2775<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4690<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2110<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4692<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2108<o></o>
</td> </tr> </tbody></table> Gear change speeds compared (+top speeds and rpm count at 60mph in top gear)
FINAL DRIVE RATIO: 4,10:1 <o></o>
<table class="MsoNormalTable" style="border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0"> <tbody><tr style=""> <td style="border: 1pt solid windowtext; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> <o> </o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 1<sup>st</sup> to 2<sup>nd</sup><o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 2<sup>nd</sup> to 3<sup>rd</sup><o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 3<sup>rd</sup> to 4<sup>th</sup><o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 4<sup>th</sup> to 5<sup>th</sup><o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 5<sup>th (or top)</sup><o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> At 60mph<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> T5 CR<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 41mph 66km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 62mph, 100km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 90mph, 145km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 120mph, 194km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 191mph, 307km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2134 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> T5 V8<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 36mph, 58km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 91mph, 146km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 177mph, 285km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2303 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> Getrag 265<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 32mph, 51km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 55mph, 88km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 86mph, 138km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 120mph, 193km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 148mph, 239km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2743 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> M-46<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 32mph, 52km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 56mph, 90km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 88mph, 141km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 152mph, 245km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2676 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> M-90<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 34mph, 55km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 59mph, 95km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 87mph, 140km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 149mph, 239km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2744 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> W55<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 34mph, 54km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 58mph, 94km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 142mph, 228km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2879 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> W59<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 30mph, 49km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 56mph, 91km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 95mph, 153km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 142mph, 228km/<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> W58<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 37mph, 59km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 64mph, 103km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 154mph, 248km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2642 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> R159<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 37mph, 60km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 62mph, 99km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 92mph, 148km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 160mph, 257km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2551 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> AW-71<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 49mph, 79km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 83mph, 134km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 120mph, 193km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> -<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 175mph, 280km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2337 rpm<o></o>
FINAL DRIVE RATIO: 3,91:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 43mph, 69km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 65mph, 105km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 94mph, 152km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 126mph, 203km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 200mph, 322km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2035 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 38mph, 61km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 186mph, 299km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2197 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 33mph, 53km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 57mph, 92km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 156mph, 251km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2617 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2552 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 36mph, 57km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 92mph, 147km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 35mph, 57km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 61mph, 99km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2746 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 99mph, 160km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 39mph, 62km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 67mph, 108km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 162mph, 261km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2520 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 39mph, 63km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 65mph, 104km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 96mph, 155km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 168mph, 270km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2433 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 52mph, 83km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 87mph, 140km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 126mph, 203km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 183mph, 295km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2229 rpm<o></o>
FINAL DRIVE RATIO: 3,73:1 <o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 45mph, 72km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 68mph, 110km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 99mph, 159km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 132mph, 213km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 210mph, 338km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1942 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 40mph, 64km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 69mph, 110km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 100mph, 160km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 195mph, 313km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2096 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 35mph, 56km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 60mph, 97km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 95mph, 152km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 163mph, 263km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2496 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 97mph, 156km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2435 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 96mph, 154km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2620 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 104mph, 168km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 40mph, 65km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 70mph, 113km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 170mph, 273km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2404 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 41mph, 66km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 68mph, 109km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 101mph, 162km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 176mph, 283km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2321 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 54mph, 87km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 91mph, 147km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 132mph, 213km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 191mph, 309km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2126 rpm<o></o>
FINAL DRIVE RATIO: 3,54:1 <o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 47mph, 76km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> <st1:metricconverter productid="72 mph" w:st="on">72 mph</st1:metricconverter>, 116km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 139mph, 224km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 221mph, 356km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1842 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 42mph, 67km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 72mph, 116km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 105mph, 169km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 205mph, 330km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1988 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 63mph, 102km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 172mph, 277km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2369 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 102mph, 164km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 177mph, 284km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2311 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 101mph, 163km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 164mph, 264km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2486 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 110mph, 177km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 43mph, 68km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 74mph, 119km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 179mph, 288km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2281 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 71mph, 115km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 106mph, 171km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 185mph, 298km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2202 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 96mph, 155km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 139mph, 224km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 202mph, 325km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2018 rpm<o></o>
FINAL DRIVE RATIO: 3,31:1 <o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 51mph, 81km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 77mph, 124km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 111mph, 179km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 149mph, 240km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 237mph, 381km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1723 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 112mph, 181km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 219mph, 353km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1859 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 107mph, 171km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 184mph, 296km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2215 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 69mph, 111km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 109mph, 175km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 189mph, 304km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2161 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 42mph, 68km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 72mph, 117km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 108mph, 173km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 108mph, 174km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 176mph, 282km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2325 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 70mph, 112km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 117mph, 189km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 149km/h, 240km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 45mph, 73km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 79mph, 127km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 191mph, 308km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2133 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 46mph, 74km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 76mph, 123km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 114mph, 183km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 198mph, 318km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2059 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 61mph, 98km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 103mph, 166km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 149mph, 240km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 216mph, 347km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1887 rpm<o></o>
The driven wheel diameter used in these tables in 62cm, 24,04 inches. gear change rpm is 6800 rpm.
The first set of tables will tell you the difference between the gears, the rpm drops and the rpm drop percentage.
The second set of tables will tell you that at what speed does one shift when shifting at 6800 rpm, and it also tells you the theoretical top speed and the rpm count when driving at 60mph in top gear.
The ratios for the boxes have been found from internet, exept for M46 and Getrag 265. Those came from a Volvo orig. green overhauling manual and a BMW Bentley manual.
Ratios compared:
T5 close ratio (later referred to as T5 CR): 2,95:1 ? 1,94:1 ? 1,34:1 ? 1,00:1 ? 0,63:1<o></o>
<table class="MsoNormalTable" style="width: 391.1pt; border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0" width="521"> <tbody><tr style=""> <td style="border: 1pt solid windowtext; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> <o> </o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> Rpms<o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> Rpm Drop<o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> Rpm Drop %<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 1<sup>st</sup> to 2<sup>nd</sup><o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4472<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2328<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 34<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 2<sup>nd</sup> to 3<sup>rd</sup><o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4697<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2103<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 31<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 3<sup>rd</sup> to 4<sup>th</sup><o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5075<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1725<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 25<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 4<sup>th</sup> to 5<sup>th</sup><o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4284<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2516<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 37<o></o>
T5 V8 Mustang: 3,35:1 ? 1,93:1 ? 1,33:1 ? 1,00:1 ? 0,68:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3917<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2882<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 42<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4686<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2114<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5113<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1687<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4624<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2176<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 32<o></o>
Getrag 265, BMW E28 528i, 535i: 3,82:1 ? 2,20:1 ? 1,40:1 ? 1,00:1 ? 0,81:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3916<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2884<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4327<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2473<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 36<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4857<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1943<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 29<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5508<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1292<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 19<o></o>
</td> </tr> </tbody></table>
Volvo M46: 4,03:1 ? 2,16:1 ? 1,37:1 ? 1,00:1 ? 0,79:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3959<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2841<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4313<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2487<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4964<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1836<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 27<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5372<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1428<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 21<o></o>
Volvo M90: 3,54:1 ? 2,05:1 ? 1,38:1 ? 1,00:1 ? 0,81:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3938<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2862<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4578<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2222<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 33<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4928<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1872<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 28<o></o>
Supra W55: 3,57:1 ? 2,06:1 ? 1,38:1 ? 1,00:1 ? 0,85:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3924<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2876<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4555<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2246<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4927<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1873<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5780<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1020<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 15<o></o>
Supra W59: 3,95:1 ? 2,14:1 ? 1,27:1 ? 1,00:1 ? 0,85:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3684<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 3116<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 46<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4036<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2764<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 41<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5354<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1446<o></o>
Supra W58: 3,28:1 ? 1,89:1 ? 1,27:1 ? 1,00:1 ? 0,78:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-3918<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4569<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2231<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5304<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1496<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 22<o></o>
</td> </tr> </tbody></table> <o> </o>
Supra R154: 3,250:1 ? 1,955:1 ? 1,310:1 ? 1,000:1 ? 0,753:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4090<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2710<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 40<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4557<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2243<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5191<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1609<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 24<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-5120<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 1680<o></o>
Volvo AW71: 2,45:1 ? 1,45:1 ? 1,00:1 ? 0,69:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4024<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2775<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4690<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2110<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.75pt;" valign="top" width="130"> 6800-4692<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 97.8pt;" valign="top" width="130"> 2108<o></o>
</td> </tr> </tbody></table> Gear change speeds compared (+top speeds and rpm count at 60mph in top gear)
FINAL DRIVE RATIO: 4,10:1 <o></o>
<table class="MsoNormalTable" style="border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0"> <tbody><tr style=""> <td style="border: 1pt solid windowtext; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> <o> </o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 1<sup>st</sup> to 2<sup>nd</sup><o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 2<sup>nd</sup> to 3<sup>rd</sup><o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 3<sup>rd</sup> to 4<sup>th</sup><o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 4<sup>th</sup> to 5<sup>th</sup><o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 5<sup>th (or top)</sup><o></o>
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> At 60mph<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> T5 CR<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 41mph 66km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 62mph, 100km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 90mph, 145km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 120mph, 194km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 191mph, 307km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2134 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> T5 V8<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 36mph, 58km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 91mph, 146km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 177mph, 285km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2303 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> Getrag 265<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 32mph, 51km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 55mph, 88km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 86mph, 138km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 120mph, 193km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 148mph, 239km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2743 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> M-46<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 32mph, 52km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 56mph, 90km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 88mph, 141km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 152mph, 245km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2676 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> M-90<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 34mph, 55km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 59mph, 95km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 87mph, 140km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 149mph, 239km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2744 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> W55<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 34mph, 54km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 58mph, 94km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 142mph, 228km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2879 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> W59<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 30mph, 49km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 56mph, 91km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 95mph, 153km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 142mph, 228km/<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> W58<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 37mph, 59km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 64mph, 103km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 154mph, 248km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2642 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> R159<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 37mph, 60km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 62mph, 99km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 92mph, 148km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 160mph, 257km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2551 rpm<o></o>
</td> </tr> <tr style=""> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 74pt;" valign="top" width="99"> AW-71<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 49mph, 79km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 83mph, 134km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 120mph, 193km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> -<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 175mph, 280km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2337 rpm<o></o>
FINAL DRIVE RATIO: 3,91:1<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 43mph, 69km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 65mph, 105km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 94mph, 152km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 126mph, 203km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 200mph, 322km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2035 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 38mph, 61km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 186mph, 299km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2197 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 33mph, 53km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 57mph, 92km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 156mph, 251km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2617 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2552 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 36mph, 57km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 92mph, 147km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 35mph, 57km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 61mph, 99km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2746 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 99mph, 160km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 39mph, 62km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 67mph, 108km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 162mph, 261km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2520 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 39mph, 63km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 65mph, 104km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 96mph, 155km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 168mph, 270km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2433 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 52mph, 83km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 87mph, 140km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 126mph, 203km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 183mph, 295km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2229 rpm<o></o>
FINAL DRIVE RATIO: 3,73:1 <o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 45mph, 72km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 68mph, 110km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 99mph, 159km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 132mph, 213km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 210mph, 338km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1942 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 40mph, 64km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 69mph, 110km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 100mph, 160km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 195mph, 313km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2096 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 35mph, 56km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 60mph, 97km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 95mph, 152km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 163mph, 263km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2496 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 97mph, 156km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2435 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 96mph, 154km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2620 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 104mph, 168km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 40mph, 65km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 70mph, 113km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 170mph, 273km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2404 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 41mph, 66km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 68mph, 109km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 101mph, 162km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 176mph, 283km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2321 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 54mph, 87km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 91mph, 147km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 132mph, 213km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 191mph, 309km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2126 rpm<o></o>
FINAL DRIVE RATIO: 3,54:1 <o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 47mph, 76km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> <st1:metricconverter productid="72 mph" w:st="on">72 mph</st1:metricconverter>, 116km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 139mph, 224km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 221mph, 356km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1842 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 42mph, 67km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 72mph, 116km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 105mph, 169km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 205mph, 330km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1988 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 63mph, 102km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 172mph, 277km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2369 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 102mph, 164km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 177mph, 284km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2311 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 101mph, 163km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 164mph, 264km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2486 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 110mph, 177km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 43mph, 68km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 74mph, 119km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 179mph, 288km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2281 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 71mph, 115km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 106mph, 171km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 185mph, 298km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2202 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 96mph, 155km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 139mph, 224km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 202mph, 325km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2018 rpm<o></o>
FINAL DRIVE RATIO: 3,31:1 <o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 51mph, 81km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 77mph, 124km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 111mph, 179km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 149mph, 240km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 237mph, 381km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1723 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 112mph, 181km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 219mph, 353km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1859 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 107mph, 171km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 184mph, 296km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2215 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 69mph, 111km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 109mph, 175km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 189mph, 304km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2161 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 42mph, 68km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 72mph, 117km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 108mph, 173km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 108mph, 174km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 176mph, 282km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2325 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 70mph, 112km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 117mph, 189km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 149km/h, 240km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 45mph, 73km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 79mph, 127km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 191mph, 308km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2133 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 46mph, 74km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 76mph, 123km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 114mph, 183km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 198mph, 318km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 2059 rpm<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 61mph, 98km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.35pt;" valign="top" width="94"> 103mph, 166km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.1pt;" valign="top" width="93"> 149mph, 240km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 67.8pt;" valign="top" width="90"> 216mph, 347km/h<o></o>
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.05pt;" valign="top" width="93"> 1887 rpm<o></o>
