sloopy
2-digit whp
- May 25, 2020
- North Texas
I'm making this thread because I think this is a little different than the issue in the other thread (https://turbobricks.com/index.php?threads/b230-t5-3k-rpm-shake.352028/)
I recently did a t5 swap on my b230f powered 240. Incredible transmission. I'm loving the close gear ratios (2.95 first and 0.73 fifth) and I'm loving how fast I can shift this thing. I have noticed in lower gears that I have the infamous decel gear rattle around 2500-3000 rpms, but its not bad and doesn't bug me much because it's just a funny transmission noise.
What gets me is that there is an incredible resonance inside the car specifically in 4th and 5th gear. I need to drive the car again to really narrow down the rpm window, but I know that at 3000 rpms in 4th and 5th gear, the body of the car resonates and creates an awesome noise in the interior. I say awesome because it sounds really cool, but it's a very boomy and overwhelming noise which is not so nice to live with.
I'm using the stock 2-piece driveshaft modified to take the regular slip yoke. I used a yoshifab crossmember with a stock 5.0 mount and yoshifab engine mounts. I swapped the yoshifab engine mounts for some volvo 164 engine mounts which helped with vibrations at idle, but it didn't seem to do much if anything about the resonance. The next thing I was going to try was modifying an oem crossmember to mount the t5 since the oem crossmember has isolation where it mounts to the frame.
Has anyone dealt with this and solved it? Does anyone just not have this problem?
