Turbo Jake
- Feb 2, 2007
- CT
Wondering about the underdrive pulley...is it worth it? post any results. The only one I have found is from Australia. http://avalancheperformance.com/products.htm
Avalanche is from Canada, not Australia.
Jordan
Gosh folks, I was kidding mostly. I didn't mean to touch a Canada Post nerve there. But my wagon is on jack stands awaiting the arrival of a short throw shifter from Dale. I'm a little anxious to get it back on the road.
That isn't Canada Post's fault so much as it is the sender's...
It's on the way though...
What advantages are there to be had ??
Maybe Dale can post up the weight of his UD pulley and the weight of a stock pulley?
pretty sure the stock pulley is right aroun 7lbs.Maybe Dale can post up the weight of his UD pulley and the weight of a stock pulley?
yeh, powerin the electrical has been my one concern about running this pulley. I suppose I could just run a higher idle but i was also considering going with a 30% overdrive alt pulley if possible. dale's underdrive pulley is 30% under so that at least would balance out the running of the alternator.maybe a low weight stock size pulley? I have to keep the power to the beats!
