Vacuum Switch B23F
Superloop
1983 242 b23f lh2.1 w/ Chrysler ignition.
Can someone tell me what this is? I cannot find a definitive answer. It definitely seems factory, but is capped. Best guess so far has been an unused over pressure or charge air overpressure switch as if my car was to be turbo’d but wasn’t. Could also be possible related to ignition or egr?
I can only guess what that switch is used for. Maybe look around on ozvolvo.org/archive for a Volvo green manual on engine management and accessories. It might be a switch used for cruise control?
Find TP30413 from ozvolvo, then look at pdf page 23. From what I can tell, it's a vacuum switch that signals "Idle" to the ECU and Chrysler box (instead of an Idle switch on the throttle body).
It was part of a recall involving 1983-84 240s with the LH 2.0 injection system. The cars were emitting too much CO for the California emissions standards. So, Volvo's solution was to install a vacuum switch to help lean the cars out. I've only come across one B23F that has been so modified. Was an "802" part number engine from an '83 242DL that I picked up for our old '85 245DL when the B230F in that car lost oil pressure. Every other B23F I've dealt with has been unmodified in this way. They all passed the WA emissions tests without problems, though.
Retards the timing as is done by the idle contact for the Chrysler ignition on the tps on decel & high vac cruise per the TSB for CA smog, but nowhere else has CA type NOX tests on the higher compression B23F that are likely to fail said test, so seldom seen?
No TPS on the LH1.0 models / believe it is the same switch, but have not compared part #s nor vac tested one in some time. Presumably Volvo had some left over from the LH1.0 models to band-aid the 802 flat top piston B23Fs to squeak them past CA NOX / retard the timing a bit under highest vacuum situations?
Thanks all. Quite a niche little piece of equipment, no wonder I couldn’t find anything online.
On the fence about leaving it as it’s not bothering anyone. If I do remove it, does anyone know if it is more likely normally open or normally closed?
On carbed cars in other places in the world, there is a 12v solenoid in that spot that when connected to another vacuum valve and the intake manifold, it opens a loop of fresh air into the intake area from the vacuum of the connection on the intake manifold to compensate the idle up when the ac compressor clutch is engaged electronically. the 12v normally runs from the same cable that engages the ac compressor
