red740t
- Sep 29, 2008
- sarasota, fl
Those will probably be fine. Make sure you get retainers as well. The VW springs come in a few different diameters.
will the VW retainers work with the volvo keepers?
You know I appreciate the facts.
OK, so I did some spring measuring, and compiled some notes from all the spring sets I've measured.
You will find the spring force at installed height (38mm/1.5in), force at bind and bind height, max lift (bind height +1mm), spring rate, and spring force at 12mm lift using a 38mm installed height. Now you can move the spring forces around with spring shims and playing with the installed height.
Stock small diameter spring: 55-60lbs @ 38mm, Coil Bind: 200-210lb @ 24.8mm, max lift ~12.2mm. Rate: ~265lb/in. 185lbs @ 12mm lift
Retainer/spring mass: 18g, 40g
Stock MID diameter spring, OD 29mm: 70lb @ 38mm, Coil Bind: 200lb @ 24.5mm, max lift ~12.5mm. Rate: ~243lbs/in. 185lbs @ 12mm lift.
Retainer/spring mass: 19g, 48g
Old RSI(?) single spring and Large dia OEM retainer: 135lb at 38mm, Coil Bind: 280lb @ 22.6mm, max lift ~14.4mm. Rate: ~240lb/in. 250lbs @ 12mm lift
Retainer/spring mass: 21.4g, 48.8g
Single Culberro Spring: 110lb @ 38mm, Coil Bind: 230@21.3mm, max lift ~ 15.5mm. Rate: ~210lb/in. 210lb @ 12mm lift
Retainer/Spring mass: 19g, 46.8g
Yoshifab Beehive: 108lb @38mm, Coil Bind: 240@24mm, max lift ~13mm. Rate: 240lb/in. 220lbs @ 12mm lift.
Erland Cox Dual Springs: 100lbs @ 38mm, 275lbs @ 16mm lift (bind is 19mm), Rate: 275lb/in. 230lbs @ 12mm lift
BTR SP008: 70lb @ 38mm, Coil Bind: 275lb @ 22.1mm, max lift 14.9mm, rate 330lb/in. 225lbs @ 12mm lift.
Spring mass: 38.6g
For BTR SP008 use Ferrea retainer #E12014, will need to find lower spring seat or use small diameter Volvo spring seat with excessive play.
I'll weigh some retainers and add their weights later on. If anyone has the weight of the Yoshifab retainer, that would be great!
Beauty.I'll make a shared g-doc for the info, and update it as I measure more springs.
And Done: https://docs.google.com/spreadsheets/d/1loYP0y8YcifGIaVvr8JKnAcBQscUKzfzy9CCfjYJ7to/edit?usp=sharing
I was going to add in the KL Racing single and duals that I've installed.. but they are way off from their listed values. I measured the duals at 140lbs installed, and they list them at 100-110...
I do know their retainers are heavy at 24g
if the vw springs and keepers work does that mean the scat 37mm type I valves would work too?
Gen III/IV Hemis use the same valve spring keepers as Redblocks. The spring retainers (pn 53021676AB) o.d. at 0.890 and i.d. at 0.640 and weigh 8.9g. They have a -0.060 installed height vs the Ford 6.2 Raptor retainers I use with the Ford 4.6 4v springs, I'm not sure how they relate to stock Volvo retainers as far as installed height. I wonder if they would work properly with the BTR springs, they fit well with Manley 221434 beehives that are an upgrade in seat and rate to the Ford spring mentioned previously.
I mention them because they're CHEAP, 4 clams a piece or something like that. I get employee discount at out CDJR store and paid less than $3 ea.
Welp looks like my favorite BTR springs are NLA.
PAC 1223 or 1223X is still available and similar rates.
Sounds like someone has been leaking my research.
Ah, I just ordered a set from the last place I saw them available and had my order canceled yesterday. Just a coincidence then.
I was thinking of offering a drop in spring kit with beehives, but the cost to produce the retainers and locators is higher than purchasing them through Summit... sooooooo yeah. I may as well let people know what they can do for cheap-ish (still probably $200-225 for a 8v setup).
