Volvo 240 hard brake lines
VolvoLatAm
Colombia
Been chatting over email with VP about brake hard lines.
For those who don't want to do your own hard lines with the special expensive tool:
VP Autoparts has every pre-made hard line in stock for 79-93 Volvo 240s, all are copper/nickel line, with brass fittings.
you will need:
(4) front outer hard lines: #1229857
https://vp-autoparts.com/en/artiklar/brake-line-240-outer-79-93-lh-rh.html
(2) front to rear long lines #1277124
https://vp-autoparts.com/en/artiklar/brake-line-240-long-78-93.html
(1) rear left #1277112
https://vp-autoparts.com/en/artiklar/brake-line-240-260-lh-rear-75-93.html
(1) rear right #1277114
https://vp-autoparts.com/en/artiklar/brake-line-240-260-75-93-rhr.html
(2) front left #1277316
https://vp-autoparts.com/en/artiklar/brake-line-inner-78-93-lhf.html
(2) front right #1277121
https://vp-autoparts.com/en/artiklar/brake-line-240-inner-78-93-rhf.html
(1) master cylinder front #1277117
https://vp-autoparts.com/en/artiklar/brake-line-240-master-cylinder-union-fro.html
(1) master cylinder rear #1277118
https://vp-autoparts.com/en/artiklar/brake-line-240-master-cylinder-union-rea.html
total cost is like $213 as of jan. 2023
_____________________________________________________________________________________________________
Soft lines:
2 rear #1229100
https://vp-autoparts.com/en/artiklar/brake-hose-164-240-260-75-93-rear-lh-rh.html
4 front #1229347
https://vp-autoparts.com/en/artiklar/brake-hose-240-260-79-93-front.html
for the soft lines, I prefer the technafit braided lines sometimes found on FCPeuro for cheap
Radtap
Tucson, Arizona
Not bad price to replace all those hardlines, can't imagine shipping is going to be nice on those longer ones though, thanks for putting this together
VolvoLatAm
Colombia
yeah not bad at all considering the cost of the specialized tool, VP put the list together, just adding here to not go to waste!
GTJordan
Been here for too long
Edmonton AB
I just bought lines from the dealership I work at. They came the correct length with the ends on. Just bend to fit.
Well- I got the rear axle lines. I didn't check the others if they were still in stock or not. My cost was around the VP prices, but in Canadian, and I didn't have to pay shipping.
VolvoLatAm
Colombia
same materials?
