volvo 242 b230ft swap fuel pump question.
Sven's245
bothell wa
So originally my 1984 242 had a b21ft k-jet engine in it. well I ripped that out and rebuilt and installed the b230ft from a 95 740 turbo. Long story short, It runs great with nice power but I was told when I did the swap I could still use the same 'in line' fuel pump from the b21ft. so I did. Ive put over 10k on this swap already and on occasion it would pop the fuse for the fuel pump..
yesterday the car died while driving but no fuel pump fuse popped. I got it to fire up but only for about 2 mins before it died again. towed it home then I hit the fuel pump a couple times and it ran fine and pump also primed when I turned key to 'on' position.
should I be using the fuel pump from the 740 turbo or jus buy a new b21ft pump?
thanks!!
Could be a dying pump or could be an issue with the wiring.
I'd replace the wiring 1st, with new wire and it might not hurt to go 1 or 2 sizes up in gauge.
yea im thinking it could be a wiring issue because it random when it happens. im looking for a fuel pump wiring diagram
thanks!!
If it's noisy change it, otherwise run it.
