volvo classic gone green (hydrogen content) 40+ MPG
First of all I am posting here becouse it will not let me upload attachments in off topic. If needs to be moved feel free. Ok so I have this customer who works at NASA in Hamton VA. He owns a classic wagon that gets 41-43 MPG,He is some type of scientist. Anyway he brought his car over for some work. I looked inside and seen a box with a dail and I was like WTF. proceed to open hood to find what appeared to be moonshine shipment. Anyway this car is a classic wagon with a M47 5 speed. The Nitrogen set up is what was explained to me as a dual cell system. It uses 2 jars with stainless wire wrapped around carefully cut plexiglass inside. ( would not disclose how much and many wraps to make per jar) The system is ran with 6 volts dc going across both plates in the jars. It has plastic lids for insulators and over pressure releif valves, and feed directly into the engine via a vaccum line to intake mani. There is also a check valve system in line to keep any engine psi from going back( backfire or whatever the issue) for safety measures. It uses 2 quarts of 100 percent distilled water added to a teaspoon of baking soda per jar. Only has to be topped of once a month and drives 30 mins to work each way. It was awsome to see how fast when power applied it started making hydrogen. Total system only pulls 2 amps and has a 7.5 amp fuse. Thi picture is from a phone. I plan to take some more photos tomarrow. The only other mod he added is a electrical box that once in closed loop he can change the o2 sensor signal to lean it out more. I think it is awsome and I was shown his mileage records. he is getting a 12 MPG gain from 100.00 worth of parts. awsome
