spock345
Carb Loading
- Nov 3, 2016
- Livermore, CA
Well that explains some of the noises.
Do you know if the later r0,960 round face speedo guts are the same as your earlier square face speedo? If so, I have a couple later 85 mph clusters that I'll make you a good deal on. I ran one of them for a while and the speed seemed pretty accurate, the other one was off ebay and I only got it for the VR sensor. I think the odo is working on both.
Edit: gratuitous pic of my blue wagon - spider eyes FTW
Those look like the oil filter was sitting on the passenger mount. Nice to get rid of the funny noises and engine/trans movement. Probably got a lot more torque going to the wheels.![]()
I just went and bought a spray can advertised as paint code 139-2. It was close enough. The car will need some work eventually in the paint department. It was resprayed at some point and the clear is failing.looking good, hows the paint match on the cowling area? what did you do to match it ?
Maybe also flush the cooling system because I forgot to do that with the heater core in the new HVAC box before installing it.
Yep, new filter in it and the oil was changed last weekend.BTW if you do adjust the mixture. Be sure to be using fresh oil and clean new air filter. Those are required when doing the mixture adjustment.
