spock345
Carb Loading
- Nov 3, 2016
- Livermore, CA
Well, I've fixed the part where it skips badly, that was gummed up grease in the pivot. Cracking open the motor is next.Did you end up fixing your wiper issues? Biggest issue I found was that the grease in the motor goes bad and after cleaning/replacing the grease they work great
Second is bad ground at the motor
In K-jet news. I got a digital tach/dwell meter to replace the definitely out of whack ancient NAPA one I have. Got the frequency valve duty cycle at spec. The hesitant start seemed to be the aux air valve.
New problem though, the steering rack started leaking. Not bad yet as far as I can tell.
