spock345
- Nov 3, 2016
- Livermore, CA
A few months ago 122Power listed a pair of wagons (1977 and 1980). They languished for a bit in Vacaville. Meanwhile I was looking for a truck. Decided to go check the 1980 while heading home from Sacramento. A week later it is sitting in my driveway instead of a truck. Really a very clean example of a wagon. Probably the cleanest Volvo I've gotten to start with.
It has a B21F with an M46 and 3.54:1 rear end.
I am not quite sure what to make of the odometer. I know it works. Might be too good to be true. The car has seen some work in the past.
Definitely a respray, I think light blue was originally a single stage paint. Decent patina on the hood though.
Decently clean interior, normal seat wear on the fronts and minor lean on the drivers seat. Really trivial upholstery work to do compared to my other cars. The back is pristine.
Now for what needs to be done.
Done:
I don't think I'll be modifying this car much beyond maybe some nice tires, upper and lower chassis braces, maybe a thicker front sway bar.
- Rust bubbling on the windshield bottom edge needs to be fixed, I poked it a bit and it seems solid, but the trim and possibly the windshield has to come out.
- Paint work other than the minor rust, maybe at some point.
- Tow hitch
- Window scrapers and channels
Done:
- Heater valve is frozen
- Front seat rebuild.
- Rebuild brakes, vented front rotors
- Windshield washers in the front need work, rear wiper motor is loose in the trunk, more diagnosis needed. Really splitting hairs at this point.
- The OD switch wasn't working, fixed that the day after I bought it by making some new terminals.
- Needs a new reverse light harness.
- Upper chassis braces
- Engine harness is biodegradable, new harness included with the car.
- PCV setup is a quick fix at present to make it look and operate somewhat right so it would pass smog. Hey, it works, but might as well get the proper parts on there.
- Motor mounts
- Investigate bushing condition, maybe a front sway bar upgrade (went to 23mm front)
