redblockpowered
bad username length
- May 5, 2015
- Swampscott, MA
Thanks - must have missed the email.
drive.google.com
drive.google.com
how do you sleep at night?As I said, sometimes the calculations are wrong.
Pretty poorly most times, but this forum has nothing to do with that.how do you sleep at night?
If you are sleeping poorly the Ozone CBN gummies and Gron Blackberry Pearls help me sleep better.Pretty poorly most times, but this forum has nothing to do with that.
15deg of duration change is a lot! Thanks for doing that!I said this on Facebook but reposting here:
For this one we did actually check from .010" to .016" as per culberro's suggestion (sort of). I totally forgot to add that to the sheet.
Intake/Exhaust
.010" 301/305
.011" 297/303
.012" 294/301
.013" 292/297
.014" 289/294
.015" 288/291
.016" 286/288
Shows why valve lash can really change how these engines run.
If you look at the advertised duration vs duration at a specific lift you'll see it as well. Like advertised duration might be 290deg, but at 0.050" lift it's 225-230deg.Hi,
I'd like to understand the above statement a bit better. What makes the valve clearance variation reduce or increase the cam duration by that amount? If the valve is closed, the clearance doesn't seem to matter, however I can kind of understand that it will effect the valve timing once the cam starts to open and close the valve. I just cannot figure out how only 0.006" difference equals that much difference in how long the valve stays open.
For what one?I said this on Facebook but reposting here:
Intake/Exhaust
.010" 301/305
.011" 297/303
.012" 294/301
.013" 292/297
.014" 289/294
.015" 288/291
.016" 286/288
Do you actually recommend that, though? There has to be SOME reason Volvo wants double or more of those numbers. I did also have a 760T that had a mild turbo camshaft in it that wouldn’t pass emissions testing with some 0.012” intake valve clearances. Loosening them up to 0.016” did the trick.0.006-0.008in intake, 0.010-0.012in exhaust is pretty common for a lot of engines.
I ran my turbo car at 0.008 and 0.010” for years with an IPD turbo cam.Do you actually recommend that, though? There has to be SOME reason Volvo wants double or more of those numbers. I did also have a 760T that had a mild turbo camshaft in it that wouldn’t pass emissions testing with some 0.012” intake valve clearances. Loosening them up to 0.016” did the trick.
