KL Racing T2 measurements
I installed, drove, and measured a KLR T2 cam. I'll first make some objective comments to demystify this cam, and then I'll give some thoughts.
KL Racing lists the T2 as 280° duration ("major on running clearances"), 11,3mm lift, and 112° LSA. They also have the T3 which only lists peak lift as being different (12,15mm for T3). KL Racing says, "KLR T2 Suitable for engines with slightly larger Turbos and increased boost pressure, gives a significant increase in power for such a gentle camshaft. Has good idle and low speed." On their website they also list the T2 as recommended for turbos from 16T to K24, which are small turbos especially for the Swedes.
The duration, measured at the recommended 0,35mm lash, is only a couple degrees less than the T3. Like the T3 it comes off the seat fast, and the ramp is faster than an OE cam. This is very evident in how it drives, it delivers similar performance as a K but with nicer drivability.
I see a lot of people online complain about this cam. There are 1 or 2 dyno results that I've seen that are impressive, and a lot more where it's "nothing... nothing... nothing.. peak-power-rev-limiter". People say the T2 is gutless down low and too big for a TD04HL. Also like the T3, I needed to advance the T2 16° to reach the recommended 2,5mm of intake lift at TDC on my motor with a 0.050" shaved head and 0.036" head gasket. I'm convinced that most people running KLR cams just throw it in, and maybe, advance it a couple degrees, and then complain that it doesn't run well. It is an absolute must to degree the cam when installing. Don't get afraid if it needs 16° of advance, that's an arbitrary number based on where the pin was on the cam blank before grinding. Set it to TDC and forget about it.
It is also a must to use new shims. The ramp is aggressive, if you have old shims they may be worn. I've gotten some wear on the lobes from the edges of the shims. It's not on the peak of the lobe so I say it's fine. I would also not run more than the recommended valve lash. The ramp off of the seat is already really fast.
How do I like it on my simple NA engine and AW70? It's fantastic. It's docile to drive at low speeds, idles acceptable (better an K, worse than V), and is responsive under 3k rpms. It's not gutless, and it doesn't behave at all like it's over cammed. I like the 0.430" of valve lift which is 0.25 of the intake valve diameter, I like the fast ramps and large area under the curve, and I like that it makes broad power and never feels like it's coming on cam. I think this could be a great cam for a 300whp redblock with stock valves and manifolds. I'd like to try it with a smaller turbo now.
Some comments on the spreadsheet:
I added my own 0,5mm and 0.050" measurements. I did not think that measuring the duration at another number and then calculating back in the lash to find the overlap @ x number to be useful, I want the actual duration at that lift number. I also calculated the centerline angle at every lift measurement. The measurements are all consistent but I believe because of how the cam was loading and unloading the measurements appear to advance. I chatted with RBP about this and I think it's fine.
