84B23F
- Feb 11, 2008
- Kansas, USA
These are 2-barrel, progressive, down-draft carburetors that are designed for 1200cc - 2300cc sized engines. 32/36 DGV sold in US, and 32/34 DGV sold in Europe were designed mainly for fuel economy, and 38 DGAS or 38 DGES for better “throttle response at a slight penalty in fuel economy.”
In USA, Redline ships kit versions of them tuned to specific stock engines. On non-kit versions, 22680.005 is jetted for 1600cc engine (Formula Ford 1600), and another, 22680.033B is claimed to be jetted for 2200cc engine at online retailers. In Europe, I've seen 32/34 DGVs jetted for different engine sizes.
These carburetors should be jetted for a given engine. Redline, the US distributor of Weber's products, has bundled kits available for specific stock-engines. Pierce Manifolds might jet them correctly if bought from them. “Weber Catalog and Adjustment Setting Tables” pamphlet(s) should be available to Weber based businesses. I only found this jetting table but if a kit is available and tuned for your engine, I highly suggest buying it.
There are two issues with a DIY jetting:
1. There are 5 different parts that must be considered, and
2. finding/buying these parts in US (I've seen European sites with them)
There is a “Weber Factory Tuning Manual” still available (book/pdf).
Weber offers a 32/36 DGAV-IC and 32/36 DGEV-IC carburetors which have a solenoid that shuts off fuel to the idle circuit when the engine is switched off. Apparently, in later model engines, this is needed to prevent “run-on” (dieseling) when engine is shut down.
Sidebar - After digesting this thread,
I concluded there were misunderstandings about Weber Carburetors, which imho, are very good, if jetted correctly.
B20 Gurus, need a carb recomendation for a mild DD
The B20 in the 75 is due for an overhaul. The shortblock is good, but the head is shot and the k-jets are dying. I'm sick of messing with the mechanical injection, and the lines are rotting one after another. I don't want to do an efi conversion, so carb is looking like a good way to go. The...
turbobricks.com
