digital.aaron
S powered
- Feb 10, 2012
The car:
1976 246
1992 b230f
B cam
Bosch breakerless ignition
Kjet fuel pump&relay
Lh2.2
The problem:
I just finished putting the b230 in last week. The first start was a little rough and took a few tries. I chalked it up to not having gas in the rail. Car ran a minute and then I shut it off. Later that day I started it again to move it out of the garage. The first symptom started happening. I could crack the starter, but after a couple rotations, everything would just chug and the electrical system would quickly fade out. It seemed to do this everything it felt like the engine would actually turn over. But it started and I took it for a short drive up the block and back, and it seemed to run fine. I thought maybe because I hadn't checked the valve shims when I out the b cam in, something was too tight and causing problems. So today I did the shims. None were horribly tight, but still on the lower end of the spec. I put 6 thinner shims in, so I had looser tolerances across 3 cylinders, and thought I was good. I put almost everything back together, with the exception of the coil wire to the distributor. I didn't realize this before I I tried to crack the engine. But everything sounded good cranking with no spark. I reconnected the coil wire, and double checked everything else to make sure I didn't forget anything. I tried cranking the engine and now I get the same electrical chugging and loss of power even quicker. I haven't been able to start it since. I've also tried giving the wagon a jump start, but it had no effect on the problem.
I made sure to re check the timing each time I had to make adjustments to the cam. I don't think it's mechanical. I suspect my cheapo, but still newish, battery may have crapped out, but was wondering if anyone has seen similar issues before?
1976 246
1992 b230f
B cam
Lh2.2
The problem:
