240 what size bolts for stock pressure plate/flywheel
What year and car?
Late M46 and M47 uses M8x 1.25 x 19 mm Socket Head Cap Screws, Grade 12 hardened black oxide. These will work on the early cars after ~1974, too which came with hex bolts of the same thread. earlier than that they were 5/16- 18
Prolly Tacoma Screw, but they aren't open on Sunday. The bolts that hold the flywheel to the crank are the same between autotragic and manual. So, you can reuse the stuff you have. The bolts that hold the pressure plate to the flywheel are M8x1.25, IIRC. Have a 6mm allen head (or 12/13mm hex head, depending on what you can find).
-J
