Haven't been posting updates because progress has been in fits and starts, the end of the year had me needing to finish up a couple of work projects that kept me pretty busy.
The head went off to the machine shop to get pressure tested, ground, hot tanked, decked and the valve seals replaced. The shop mentioned it looking pretty sludgy but also said that they barely needed to take anything off to get it cleaned up:
They also tanked the valve cover for me because even after using gasket remove the anaerobic sealant was holding on. It *still* had left over sealant on it when it came back, but it came up really easily with another application of gasket remover and a plastic razor blade this time:
My pile of cleaned and painted parts is getting nearer to where it should be as well:
Up until very recently, I was completely unaware that you could disassemble and clean hydraulic lifters, so thanks Youtube.
About half of my lifters would collapse completely when squeezed when I took the engine apart, but I'm going to rehab all 24 of them. They're as sludgy as the rest of the top end, it's no wonder the check valves inside have gotten stuck. I've been soaking them overnight, two at a time, in one of those scary/stinky parts cleaner cans from NAPA, rinsing them in lacquer thinner, wiping any remaining crud out with a pair of forceps and bits of shop towel, rinsing again, then re-assembling with a bit of synthetic and the air bled out. It's pretty easy to tell they'll hold pressure.
I've also been sitting down with printed copies of the S90 and 240 wiring diagrams and filling out a master spreadsheet to figure out which wires are getting cut and spliced together. I have a 47-pin
Deutsch bulkhead fitting I'd like to use, but it's only got five positions that can take 14-16awg wires.
In an attempt to make my life easier and keep a working temp gauge, I bought a thermostat housing from a 1999 V70 that has two threaded holes in it instead of the single one in the S90 housing. Broke4speed did the same, but I realized after I got it that in his case, he's using a VW NTC sensor for the gauge, and he calibrated his ECU to use a GM LS sensor. I tried screwing the stock S90 sensor into the housing, and of course it's too long. From what I've been able to find on the Internet, it seems like the resistance curve on the S90 sensor is very similar to a
standard sensor that got used on a lot of VW/Audi/BMW stuff that should also have the right threading.
