Pap
- May 6, 2012
- Keystone State
Got one for the guru's here... My 92 940 has had this annoying problem since the day I bought it.. It would randomly lock all the doors when you would go to open the drivers door.. This led to a hidden key before I'd get locked out at the most inopportune time.. or at the ghetto-gas station, in the undesirable part of town.
It did not follow a predictable cycle of opening the door to have it lock up. Sometimes it would go 6 tries, other times a dozen. So today, I had the time to pull off the door panel and see whats up. On another Volvo forum, the one guy suggested the spring was bad on the latch and that was the cause... Today I replaced the outside door lock mechanism and pulled a spare door handle from the junked 740 wagon. After looking at the door handle, there is nothing there unusual or any spring, so I'm not bothering to replace that... I installed the new door latch and tried it... same thing.. locks me out...
Now the funky stuff...
I found the central locking relay and tried changing it... same result..
I then unplugged the door power door lock motor.. I figured this would do it for sure. Now the key/lock all feature doesn't work.. but I'd rather manually lock all the doors, than be locked out.
Well. I decided to try it before putting back on the door panel. ...
After a few tries the damn thing locked itself again... how can this be? It is nothing but the handle, the lock rod connecting to the latch, and the latch.. nothing else and it still locks by itself. The self locking bit is what tripped all the other locks to go via the sensor/power lock motor harness.
So what is left to do? the handle is a simple lever... a rod.. and a latch.. big deal... how can I fix this?
Ideas?
Cheers,
Mike
Ideas?
Cheers,
Mike
