Timing belt on correctly? My B230FT (distributor on back end of the cam) idled very poorly (bumps and spits). Found that in my case (an old timing belt) the cam timing belt had stretched enough so that it was 1 tooth off at the cam. After re-adjusting the tension pulley the cam timing belt was spot on and the car idles very smoothly.
Just thinking out loud - in your case - does adjusting the cam timing also affect the distributor timing?
Jus tdid the exact same swap ( T to A ) on an FK engine. The idle got a little rougher, but not so much that it is a problem.
