hdBattousai
- Oct 21, 2013
- Chandler, AZ - Benchracing
Trying to adjust/increase idle but my idle screw has apparently been maxed since I've owned the car. It idles at 750rpms like this. How do I adjust it back to stock so I can use the screw to adjust idle properly? Why would my car idle a 750rpms with idle screw at max?
Short story, threw in RSI stage 1 cam and trying to up idle 2 900, car starts then stops on cold, starts hot and drops to 200rpms then slowly climbs to ~600 rpms. Cold start if I go kart it till I go into second gear and release gas it drops then regulates to 750rpms, dies if I let go anywhere in first tho without hitting second.
Recently replaced iac
Right this moment I'm replacing ecu temp sensor and tps
