105Charlie
- Jan 21, 2018
Hi
I'm planning to build up a new CHRA to fit to my angled HL turbine housing that's in use on the car. Plan is billet wheel and larger cover to match, and uprated turbine wheel/shaft.
My options are rebuild current 15g in use, or get another bearing housing so the 15g can be used elsewhere.
However, I have the original 13c and I'm trying to work out if I can use the bearing housing and rebuild that with the HL shaft and wheels. I can't find any exact numbers, so apart from just attempting it, I can't work out if the bearing housings are interchangeable between all TD04s?
Thanks
Thanks
