Hi folks
I have a cool digital temp/coolant level gauge coming from Australia, and I'll post install/impressions once in hand in installed. The initial question is: what temperature should I set for the alarm that comes with it? The sensor is block-mounted.
From the manufacturer:
The gauge receives continuous engine temperature measurements from a digital temperature sensors mounted directly on the engine block.
The digital temperature sensor can measure temperatures from -55°C to +125°C (-67°F to +257°F). The gauge displays temperatures in one degree increments.
The gauge checks the measured temperature against two temperature levels (SAFE and MAXIMUM) which are set separately for the engine.
Dave
'93 240 'Sonja'
- SAFE temperature. An engine temperature at or below SAFE is normal operation.
- MAXIMUM temperature. An engine temperature at or above the MAXIMUM will flash a RED display and trigger the audible alarm. The alarm will also be triggered If the gauge cannot receive a temperature reading from the sensor. The audible alarm can be cancelled by pressing either the Menu or Settings button or can be turned off using the gauge menu/settings.
Dave
'93 240 'Sonja'
