soroushrajabnik
- Apr 19, 2013
- Los Angeles, CA
I have been nursing a leaky early style cam rack in my 78 242 and decided to try to find the best looking replacement I could by keeping an eye on my local yards inventories. Ended up pulling a later style cam rack that looks like it had been replaced not long before the car experienced it?s demise from a 91 wagon. I also pulled the newer style bracket and pump while I was at it.
I?m just realizing after doing some research that it appears cars prior to 1979 had a 14mm steering shaft, cars post 79 have a 19mm?
When I pulled the rack out of the 91, I pulled the U joints with it, separating the joints from the shaft at the upper joint. Does this mean that my 78, in theory should have a 14mm male spline on the steering shaft that will not fit into the female u joint on the 91 rack?? Should I have pulled the entire steering shaft from the 91 wagon as well?
Any insight would be very much appreciated
