mikep
Vintage Ride
- May 24, 2003
- 38? 27' N 75? 29' W
I have several types/lengths of 250-300 lb/in, and the rear cones to convert the lower to a conventional open spring.
I can't find front strut top hats for the 5.5" pigtails, I used a top from a chevy spectrum/isuzu. I'll hit the yard and see if there are any left. I doubt it.
I have corolla tops that work with conventional 5" springs, and if you decide to do towery coilovers with pvc sleeve, the tops are easy. You just need a bearing.
I also have BNE Select top mounts and lux steer (FWD volvo) top bearings.
We should talk about ride height, which will determine rear shocks. for using a 13" tall stiffer rear spring I like the Gabriel Ultra for suburban.
Keeping the front at stock height is good for roll center, but at 1" lower it isn't terrible. It just does some weird acrobatics above/below ground and left/right with softer springs in turns/bumps. Letting the rear down a bit gives you 2 degrees free caster per inch off-level.
(2) Gabriel G60008 Bruiser Suspension Shock Absorbers - Front - PAIR | eBay
Gabriel part number G60008-2. OUR CHOICE. Be sure the part you are buying is correct for your application.
www.ebay.com
