t8fanning
8v are still cool, right?
- Oct 10, 2010
- Vancouver, WA
I know this is an incredibly noob question, but I've haven't done a head gasket job before, and haven't found a really good resource for how to measure deck height of dished pistons online. I want to measure the deck height to determine what thickness of Cometic gasket I should order and if any head decking is required to get to a squish of 0.0030-0.034" as I've seen recommended here. I also want to check to see if I bent any rods with all the coolant in my cylinders.
I understand there are a few methods to measure deck height including using a straight edge and feeler gauges, or the basic idea of using a dial indicator and zeroing it on the deck and then measuring the center of the piston relative to the deck. But how do you move the indicator such that the measurements are accurate? Do you fixture everything and then remove the base and reposition so the indicator is in the center of the piston? Are you really supposed to measure to the center of the piston when it's dished? I know if I measure to the edge of the piston it could introduce error in the form of piston rocking.
Additionally, what is the recommended way to remove carbon build up on piston tops? I know that will affect my measurement.
Again, sorry for the noob questions.
Here's a picture of my carnage, failure seems to have occurred on the fire ring of cylinder 2:
