Karl Buchka
- Mar 25, 2007
- Los Angeles
Update 08/19/11
Group buy is up. http://forums.turbobricks.com/showthread.php?p=3883351
Update 05/11/11
The circuit has successfully been tested on a 940 Turbo. The car fired up and ran cleanly with no apparent issues. I need to do some more testing of my own before I send out any boards. I'll keep this updated until that time.
I've also posted the first-cut source code here: http://forums.turbobricks.com/showpost.php?p=3760567&postcount=84
Original post:
There was a thread posted a few days ago talking about options for ditching the distributor on an otherwise stock LH2.4 equipped car which got me thinking. Alex and I have been playing with this for the last day or so and we've made some good progress.
We got an EZK 146 box and tapped in to the VR conditioner circuit and the spark output. Those signals are sent to a microcontroller running a wheel decoder program that counts teeth and redirects the stock spark signal to two outputs. Here's what it looks like on the scope:
Channel 1 is the output from the stock EZK VR conditioner being fed a 4kHz sinewave with two periods missing every 58 periods (this simulates a 60-2 trigger wheel running at 4000RPM), channel 2 is the stock trigger output signal, and the other two channels is the stock signal after being split.
We've tested the circuit on the bench from 100rpm to 10000rpm with no apparent faults.
What this essentially means is you can install this circuit in your otherwise bone stock LH2.4 car, wire up a wasted spark coil, and be up and running. The main catch here is that stock dwell is retained, meaning we need to find a wasted spark coil with similar dwell characteristics to what's stock. The Bosch Motorsport 4 cylinder wasted spark coil looks to be very close and is what we'll be testing this with first. A friend of ours has a 940 Turbo that we'll be testing this on in a few days.
Piping a cam sync to this chip for full sequential would be fairly trivial.
If this works and there's any interest I might have a run of circuit boards made up. Questions, comments?
Update 05/11/11
Original post:
